2024 Toyota Tacoma Revealed
1809 Views 29 Replies 18 Participants Last post by  Akfan
7
Tire Car Plant Vehicle Sky
Has anyone seen the new Tacoma that was revealed today?
Design and Development Driven by “Tacoma-ness”
Toyota’s North American-based CALTY Design Center located in Newport Beach, California and Ann Arbor, Michigan led the design efforts for the new Tacoma, as they did with the Tundra and Sequoia that launched last year.
“Our primary design goal for the all-new Tacoma was to be authentic to the way our customers use their trucks for rugged outdoor fun,” says Kevin Hunter, president, CALTY Design Research. “We looked at our truck DNA and the Toyota Baja race trucks for inspiration to capture the extreme spirit of offroad adventure. High lift, big tires, slim body, and a powerful athletic stance define the iconic Tacoma look, referred to as ‘Tacoma-ness’.”
The CALTY team of designers focused on the theme of a “Badass Adventure Machine” when defining the essence of the new Tacoma. This refers to Tacoma’s engineered toughness along with its athletic attitude. The design team strives for Toyota trucks to have a family resemblance, each with unique personalities defined by each one’s purpose. For Tacoma, its narrow body and wide upper grille are a nod to the original HiLux, with features like the aggressive skid plates expressing the extreme ruggedness of Tacoma. Other signature design elements include the high-mount headlamps, side functional air intakes, hexagonal grille motif, as well as integrated roof and tailgate spoilers.
Engineering research and development was conducted at Toyota Technical Centers in Michigan, Arizona, and California. The collective engineering teams embraced the “Tacoma-ness” concept and worked tirelessly to develop the next-generation Tacoma as an extremely capable multipurpose vehicle that can go almost anywhere.
Improvements were made across all grades. The team enhanced Tacoma’s off-road capability, from severe rock crawling to high-speed desert racing. As a result, Tacomas will perform in widely varied environments, on road and off. This includes everything from a luxurious night out in the Limited grade or traversing Black Bear Pass in the Tacoma TRD Off-Road that is more capable than ever.
“We strove to provide even greater attribute separation between grades,” says Sheldon Brown, chief engineer, Tacoma. “Each has a distinctive focus on the core attribute and uses hardware, spec, and performance-based tuning to deliver that unique experience more so than in the past.”
Rugged Construction and Capability
The new Tacoma utilizes Toyota’s TNGA-F global truck platform shared with the all-new Tundra and Sequoia. Much like its full-size brethren, high-strength steel with blanking and laser welds is used throughout the chassis to increase rigidity over the previous generation, and aluminum is used on the upper body to reduce weight. Frame crossmembers are also strengthened to increase durability and carry Toyota-available overlanding gear such as rooftop tents and camp fridges. Additionally, the roof is equipped with integrated attachment holes that allow the ability to easily add roof rack rails on all models combined with a roof channel sealer to ensure a watertight seal. A new front cross member was constructed for the steering gear box, which adds rigidity via additional cross member support while enhancing steering input for the driver and handling dynamics. A new high lift jack point is also integrated into the rear frame end.
Also enhancing ride and handling characteristics on Tacoma is a newly available multi-link rear suspension. This system replaces the previous model’s leaf springs in favor of a set of coils. However, leaf springs remain standard on SR, SR5 XtraCab, and TRD PreRunner grades. Tacoma also now gets four-wheel disc brakes for increased braking performance compared to the previous model, while TRD models and above are equipped with a larger front brake package. TRD models and above equipped with i-FORCE MAX add a larger rear brake package. An electronic parking brake allows for low-speed radar cruise control and a brake hold function. To provide improved steering feel and facilitate the incorporation of additional safety and convenience features, Tacoma will now have electric power steering.
Tacoma now features suspensions tuned specifically to each grade. For instance, TRD Sport has red TRD sport-tuned shocks for a more responsive feel. The TRD Off-Road grade is equipped with monotube Bilstein remote reservoir shocks for extended wheel travel and greater heat dissipation and includes an end stop control valve (ESCV) that provides increased damping force as the suspension comes closer to full bound stroke. TRD Pro comes fitted with FOX’s new QS3 three-way adjustable internal bypass shocks with remote reservoirs for improved high speed off-road performance and FOX Internal Floating Piston (IFP) rear bump stops to improve bottom out feel. Trailhunter includes new Old Man Emu (OME) 4×4 Suspension by ARB that is tuned for optimum levels of off-road control and load carrying capability. Limited grade features a new Adaptive Variable Suspension (AVS) system that constantly adjusts damping forces based on changing road conditions. The linear-solenoid-type AVS system features built-in actuators in the front and rear shock absorbers to continuously change damping force based on road conditions to give the new Tacoma a smooth and luxurious ride.
Maximum towing capacity for Tacoma is rated at 6,500 lbs. on SR5 i-FORCE and TRD PreRunner XtraCab grades, and maximum payload increases to 1,709 lbs. on TRD Off-Road. To help make towing a breeze, Tacoma is available with a variety of supporting features including a trailer brake controller, trailer backup guide, and digital display mirror. Trailer Back Up Guidance aids in overall maneuvering of trailers, while the available Straight Path Assist feature is designed to help your truck and trailer back up in a straight line. The available 360-degree cameras create a top-down view to aid overall visibility, including tough-to-see areas around the truck and trailer. When operating with Toyota’s integrated trailer brake controller, the Blind Spot Monitor is designed to recognize blind spots for not only the truck, but certain trailers as well.
To make things even easier for truck duty, there is a 7-percent increase in bed volume that is useful for loading necessary gear under an available tonneau cover. Additionally, the aluminum tailgate features an available power open and close function with jam protection, and a quick release and close button is integrated within either taillight. Gas grades offer an available 400W AC inverter outlet in the bed and on the rear of the center console, while i-FORCE MAX grades come standard with a 2400W AC inverter. 12V DC power access is also available in both the bed and in the cabin. Trailhunter features an integrated high output air compressor in the bed for airing large diameter tires back up quickly after airing down for spending days, or weeks, on the trail.
Taking Tacoma to the MAX
Tacoma will offer two powerful and efficient powertrains using a 2.4-liter turbocharged four-cylinder. For entry-level SR grades, this engine produces 228 horsepower and 243 lb.-ft. of torque. For all other grades, output increases to 278 horsepower and 317 lb.-ft. of torque when paired with the new eight-speed electronically controlled automatic transmission with intelligence (ECT-i). Enthusiasts rejoice: a six-speed intelligent manual transmission (iMT2) with automatic rev matching and anti-stall technology is available. Manual transmission models produce 270 horsepower and 310 lb.-ft. of torque.
New to the mid-size, body-on-frame pickup segment is Tacoma’s i-FORCE MAX hybrid powertrain, the most powerful powertrain ever offered on Tacoma. Available on TRD Sport, TRD Off-Road, Limited, and standard on the TRD Pro and Trailhunter halo models, i-FORCE MAX pairs the 2.4-liter engine with a 48-hp electric motor integrated into the eight-speed transmission feeding off a 1.87-kWh NiMH battery pack that creates a total system output of 326 horsepower and a whopping 465 lb.-ft. of torque, nearly doubling the torque output of the current-gen truck with the V-6 engine. When equipped with i-FORCE MAX, Tacoma can ascend an 8-percent interstate grade without the need to downshift, making long road trips more pleasant than ever in a Tacoma. Fuel economy estimates for all powertrains will be announced closer to their on-sale dates.
Tacomas with rear-wheel drive feature an automatic limited-slip differential (Auto LSD), and four-wheel-drive models have an electronically controlled two-speed transfer case with high/low range along with Active Traction Control (A-TRAC) and an automatic limited-slip differential (Auto LSD). An electronic locking rear differential is standard on TRD PreRunner, TRD Off-Road, TRD Pro, and Trailhunter grades. The new and luxurious Limited grade now features a full-time four-wheel-drive system with a center locking differential on i-FORCE MAX models.
Car Plant Vehicle Tire Land vehicle
Cloud Wheel Sky Tire Plant
Wheel Tire Land vehicle Plant Vehicle
Tire Wheel Sky Cloud Land vehicle
Tire Wheel Vehicle Hood Automotive tire
Tire Wheel Vehicle Truck Automotive lighting
See less See more
21 - 30 of 30 Posts
The V6s weren't that good on gas, the 4-cylinders were a little better. Wonder what the new MPG numbers are?
The highlander went from the same 3.5 to the 2.4 turbo and gained no mpg . I imagine the truck is the same too.
Giving up a lot and gaining nothing.
2024 Toyota Tacoma - now even boxier!
I have to wonder if the cab is still horribly short. Friend of mine has a 2020 Taco and I have to bend practically in half to get my head inside to sit on the passenger side. I'm 6'2" so... I slide right into my SC.
Increase in torque and more useable at lower rpm…
The mild hybrid version will increase power and torque and mpg, although it would be minimal gain in mpg with the mild hybrid set up, wasn’t designed for fuel efficiency, rather to add more power…
The weird leg forward cab design of the old Taco, has changed - it’s more conventional seating set up…
The hybrid isn't the turbo 2.4.
I've driven the highlander 2.4 T on several occasions. Its less HP and very little more tq. Its wheezy and loud and slower in any real world situation. It gained absolutely nothing. And everyone I've spoken to at Toyota agrees. Was a bad trade in every way.
The hybrid gets 30 MPG and has an NA 2.5.
At least in the highlander. In the taco idk. I buy full size trucks myself. No interest in the big taco no matter what engine they use. I WAS buying a new highlander or Lexus this year though. Until they killed the 3.5
And I may be interested in a new FJ ish vehicle if Toyota brought one. Lol.
The mild hybrid is a 2.4turbo - available on the mid to upper trims of the next generation Taco… lower trims get the 2.4turbo with out the mild hybrid
Must be a taco thing. Lol. The highlander is a 2.5 NA with their hybrid and it gets pretty good mileage. Weak though. While all other trims of highlander got the 2.4 T . Even the grand highlander.
Lexus has used the same engine for a few years now. No reliability issues but I haven't found anyone particularly impressed with it in the sub 300 HP highlander form. The Lexus is 400. Less wheezy and probably more insulation. In the lexus . In the highlander its noisy. The Pilot is a new 3.5 and the cx90 is the new inline 6 turbo. Ill buy something else or wait to see if the grand highlander picks up a better option in the coming years. I have enough vehicles im in no hurry.
24’ Taco looks like a baby tundra for sure now ... which is ok, and I’m sure it’s reliable but...it is an uninspired rectangle to me
Reactions: 1
Hey does this Tacoma have rear drum brakes and non height adjustable driver's seat like the previous one?
4 wheel discs. Fixed on front like the previous Tundra.
21 - 30 of 30 Posts
