Vehicle Info:
Built date: 07/30/2021
Odometer reading when unloaded from car hauler: 16 (this is before the dealership tech perform the road test as part of the pre delivery inspection)
Odometer reading after PDI: 24
16 miles fresh off the truck is pretty high, that means someone in Alabama took it for a test drive, and I guess that's okay as they only randomly select units to test drive at factory and mine was unlucky that I don't know strict they follow the break-in procedure during the test drive, or lucky that they test drove it and the DCT didn't crap out on them in Alabama.
Vehicle usage:
In the 3000 miles driven, only about 600 were highway. The rest was city stop and go and frequent short trips. I consider this severe/harsh usage as there were more engine heat and cool cycles and transmission shifted way more often than avg.
In the first 1500 miles, only 92 octane fuel was used.
and the following 500 miles, I weened it off of 92 and gave it 89, and then 87 there after.
Every fuel up, I added 1 bottle of upper cylinder lubricant, that claims to clean injectors and fight ethanol corrosion.
Below is the summary of the 3000 miles.
Failures:
this seems to be the most controversial component, after 3000 miles, I don't think it shifts any better than what I can noticed since day 1. My experience is that the DCT shifts very smooth, especially the down shifts compared to traditional AT, which doesn't rev match and you would feel a jolt. In lower gears and lower speed, the clutch pads makes clicking, grinding noise from day 1, and it's not getting better or worse so I just write it off as normal.
I mentioned something about DCT hesitated to take off and stutter. That was during the break-in period I was driving it gently. After 2000 miles, once I started applying my "lead foot", it behaves great and no hesitation.
Conclusion: from the first 3000 miles, all the problems I have encountered were pretty minor. However, compare to my other Toyotas, my particular SC isn't as well built as those (I didn't experience any of those issues in the Toyotas). I will continue monitor and care for my SC, so far the problems are tolerable.
Some of you guys on the forum experienced way worse problems, I'm sorry that happened.
It must be disheartening and frustration to have your brand new vehicle and immediately it's out of commission. I appreciate that you all post the problem and Hyundai's solution, or the lack of it. We are made more aware of things to look out for, and when more of us report back and Hyundai take notice, TSB or recalls can be initiated if those problems affect certain batch or the whole recurring production.
Vehicle usage:
Failures:
- bad connection in the brake lights, as described here, happened at about 200 miles, but I believe it is bad from the factory. I blame wiring harness parts supplier or whoever assembled that of mine.
- window locking functionality not working. It worked for the first few weeks, but lately during which 1 passenger opened the window to my surprise and then I discovered the lock window doesn't work. It's not a feature I will miss so I won't get it fixed and risk dealer opening up the doors and potentially something else breaks.
- front wheel wells liner missing a few fasteners.
