While the adhesive is still fresh I decided to get rid of the badge on the tail gate
It was super easy, just dental floss and finger picking the residue
here is how it looks
Now to the first break in oil change
I got it to 532 miles, and it's roughly 50% highway and 50% city
First let's check out the dipstick and get a baseline reading of engine oil
this is by far the best dipstick I've seen, braided metal and plastic tip
Kudos to Hyundai Alabama, the oil level was spot on from factory
I've had Toyotas from the factory slightly overfilled engine oil
Now since it's only an oil change let's go on ramps
these plastic covers are held on by fasteners, use a flat screw driver to pry it open and pull the pin to release it, very easy to figure out
loosen and remove the 2 bolts with 10 mm socket
