Wanted to post this for you as well. It's a crude measurement change chart from the stock 18" wheel as a baseline for 7.5", 8.0" and 8.5" in various offsets.
Wheel width measurements are actually done on the inside of the tire mounting lip, not the outside of the wheel if you didn't know that. What really matters for this purpose is the "change" from stock. This chart helped me visualize the change to both the inside and outside measurements based on where the stock 18" rim sits.
Personally I wanted to go with an 8" wide rim. A +42 offset would approximately match the inside OEM rim location, putting all the additional 1/2" width to the outside.
With that said, I have ordered 18x8 +35 offset rims which pushes the inside lip outward about 1/4" (partly to insure clearance of the agressive sidewall tread of my tire selection - Atturo Trail Blade ATS in the stock 245/60R18 size) and the outside lip outward about 3/4". I'm also waiting for Hyundai to let us know what the factory flare kit will look like, but even if they drag their feet on that announced accessary I think it will look very nice and not stick out to far.
Hopefully by the end of next week I will have everything mounted up and installed to post a photo.
OEM bore size is 67.1mm. That or larger will work with center bore reducers which are cheap. My new rims are 73.1mm, so i will be running a 73.1 to 67.1 aluminum reducer.
