Inspired by other threads I'm starting my crossbar setup for the tonneau cover installation. First of all I have some specific goals in mind with mine. One I want the crossbars to be almost invisible when not in use. Two I want flexibility to position them based on need. Three be able to carry bicycles without spending hundreds of dollars or using the hitch. I have a very specific use case that requires me to carry the bicycle while towing the trailer. With all of these things in mind here are the parts I have on order and then my plan.
Crossbars (Cheap, black, and the right width)
Spacers that I think will look good and come in different sizes so I can raise the bars just enough to clear the handle.
Threaded knobs that will quickly allow repositioning or removal of the crossbars.
Cheap and very small footprint solution for the bicycle on the crossbars
Now my idea is to cut the crossbars so they fit in between the buttresses at the front of the bed. Hopefully the overall width of both bars isn't any wider than the roll top portion of the tonneau cover. If all goes as planned you can unthread the knobs and slide the crossbars all the way forward, hiding them when not in use. Carriage bolts will be used to go from the underside of the T-Rail up through the spacers, through the crossbars and tightened down via the threaded knobs. Allowing for a quick tool-less way of moving the crossbars around. Then the bike rack solution getting mounted to the crossbars so without any bulk the bicycle can go directly on top of the crossbars with the front wheel removed. I'll post pictures after the parts start arriving and I have a chance to start making it.
Thanks to others for posting pictures of similar setups like the 2x4 solution. These inspired me to find a way to do all of this for hopefully under $100.
Amazon.com: Rhino Rack Euro Bar Steel Roof Bar Cross Bars 59" 1500mm,Black,EB150B : Automotive
Buy Rhino Rack Euro Bar Steel Roof Bar Cross Bars 59" 1500mm,Black,EB150B: Cargo Bars - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
8mm (M8) Nylon Spacers Standoff Washers (10 Pack) 4 x 15mm, 4 x 10mm, 2 x 5mm – Black: Amazon.com: Industrial & Scientific
www.amazon.com
Innovative Components AN4C-5S3A-21 1.75" Star Knob thru hole 1/4-20 steel zinc insert black pp (Pack of 10): Amazon.com: Tools & Home Improvement
www.amazon.com
Amazon.com: Hooke Road Universal Bike Car Carrier Quick-Release Alloy Fork Lock Alloy Bed | Roof Mount Rack for 1 Bike - Cross Bars not Included : Sports & Outdoors
Buy Hooke Road Universal Bike Car Carrier Quick-Release Alloy Fork Lock Alloy Bed | Roof Mount Rack for 1 Bike - Cross Bars not Included: Bike Racks - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
