1 - 8 of 8 Posts
Looks like this blocks the car seat latches. Can you confirm? Would like seat protectors under 2 car seats.
Discussion Starter · #4 ·
Wife verified that it does cover the lower anchors probably because it's a pet cover. However, for the cost of this full cover it would not be a big deal to slit the cover at those specific locations to gain easy access to those lower anchor parts. Doesn't require a large slit.
Also, I believe you were talking about just the lower anchor points. The cover does have openings for the standard seat belts. We just didn't pull those through the cover.
When looking closer at the velcro'd slit for the seatbelt access it is right next to the anchor in the seat. So I would say you have full access to the seatbelts and the anchor. I only saw 1 anchor per side within the seat next to the seat belt latches. The top anchor points are not obstructed. This may be what you are looking for.
I should've replied a week ago about this. I did order it and the Velcro seat belt spots worked for anchors but I did have to cut slits for the outer anchors by the doors. Super easy and worth it. Works great.
1 - 8 of 8 Posts
