1 - 5 of 5 Posts
Hello, all! I’ve been working toward finding a solution to keep smaller things like grocery bags or loose items etc. from tipping or rolling around in the bed of my SC — finally figured I could make one myself, so wanted to share my design with you!
Tire Wheel Automotive tire Motor vehicle Automotive design
I based my design on two Husky storage bins from Home Depot:
Essentially, I cut the tops off of each to make them a bit shorter, cut the ends off, and put them together so I have a simple, versatile solution to tame the cargo in the bed a bit.
I designed this solution with a few things as requirements:
- leave in the bed most of the time, but be easy to remove
- ability to move forward or backward to maintain access to the under bed storage
- ability to move forward entirely under the tonneau cover mechanism
- be inexpensive
The reality is that you could probably cut the ends off of two bins, use strong duct tape to join them together, and call it a day. I used metal tape in the middle just to cover the imperfect seam.
I also reinforced the front and back with flat metal rods that I riveted to the bins for extra resilience.
I will probably add straps on the sides to attach to at least two of the bed tie downs once I figure out if the bin moves around when I’m driving or not
Anyway hope this is useful or maybe a little inspirational for your own Santa Cruz projects!
Enjoy!
Moved all the way forward:
Motor vehicle Automotive lighting Automotive design Trunk Bumper
2022 Santa Cruz SEL Premium Hampton Gray
- be inexpensive
I keep 1 Husky storage bin at the back secured with bungee cords and a load lock for groceries and other shopping trips. This solution handles 80% of shopping needs. When there is more than the Husky bin can handle the extra easily fits on the rear floor or depending on the items I can put the overflow in the bed beside the bin secured with bungee cords.
&[/URL]
- be inexpensive
Enjoy!
Thanks to your post I was able to solve my need. I bought everything at Home Depot for $23.00.
1 - 5 of 5 Posts
