brakes warped 5k miles
16K views 87 replies 31 participants last post by  GeeMo
#1 ·
has anyone experienced massive brake shimmy decelerating at 75mph? Im assuming its warped rotors its just odd that it only has 5k miles...
#4 · (Edited)
If they truly are warped, I sure would think they'd warranty them.
I had a 1996 Subaru Outback that had wrapped rotors at 7,000 miles. That POS had the worst brakes, seats and engine of anything I have ever owned. The engine had a piston pin oiling design defect. They replaced the entire engine twice before 10,000. First one was bad. Second one was the same as the first one, while Subaru Corporate tore down the first engine and determined the issue. They claimed the third engine had a fix in it, but I dumped that POS a month after the third engine was installed. I had had all I could take at that point.
#6 ·
Could also be a tire or suspension issue. I've had a tire that threw a belt internally, that I only felt when I was on the brakes. Not sure how, but my best guess is the load changing on the tire itself caused the vibration to be felt through the steering wheel. I've also had alignment issues that ended up being the culprit of small vibrations when I got on the brakes.
Big vibrations/pulsating would probably be brake rotors. Hopefully the dealer takes care of you.
#7 ·
Rotors rarely warp, see the attached PDF. Could be brake deposits or uneven transfer of pad material. I would try re-bedding the brakes. To truly warp rotors you would have to basically have to melt them. I've tracked two cars (350Z and C7 Z51) and have beaten on brakes to point where they are red and smoking around Sebring - no problems. Granted that is using proper race pads.
#9 ·
I just swapped to an SC Limited yesterday from a Kia Stinger. The Stingers are known for brake issues because they used cheap factory brake pads with the brembos and the compound from said pads would break down in clumps instead of powder and would cause braking issues/wobbles because the rotor surface now had bumps all over it. Kia changed my rotors twice in 28,000 miles for this.
Depending on who you ask you get two explanations. Ask the dealer and they say you're warping your rotor due to spirited driving and they'll make you beg for the repair to be covered even though it's absolutely 100% their fault.
Ask enthusiasts and they'll tell you that if you change the pads out for better aftermarket brands, you won't have this issue at all.
Now the test Stinger owners used to see if the rotor was fine was re-bedding the brakes by going about 50-60mph and slamming the brakes, doing this process twice back to back, which burns all build up and gets the rotor smooth again. If your braking is fine again after this then I would definitely look into some good quality brake pads and get those installed. Definitely look up other explanations for re-bedding your brakes so you're comfortable with the process before doing it. Should only take a few minutes.
Crap...now I'm worried that my SC is going to have this problem 🤦‍♂️
#15 ·
If you think these are bad brakes, I had a 09 Dodge Journey that I couldn’t get 10k miles out of a set of rotors. If you over tightened the wheels, they warp. Panic stop? They warp. Look at them sideways? They warp. I got so good at doing the brakes/rotors I could do all four in 90 mins. in my garage using a floor jack. THOSE were sucky brakes. Undersized (FCA started using bigger rotors/calipers on the 11’s and up). It wasn’t my foot either. My Jeep has 29k miles on it, everything original and over 80% left on the pads…
#16 ·
I had this rotor problem also, granted I drive down a long hill twice a day. I have about 9000 miles on my SC. So this past weekend I took my SC to the dealer and they said the front rotors were out of spec. The way they explained it was the rotor had hot spots... Anyways they re surfaced the both front rotors and oddly they feel better than new. Also, before I had a slight squeak when braking and now that is gone. I didn't break the brakes in properly when I first got my SC. Fixed under warranty, so I'm happy.
#19 ·
So, is there any reason that the Hyundai dealer wouldn't cover this brake issue? I just dropped my Santa Cruz off for its first oil change (5,120 miles) and mentioned that I can feel a judder when I apply the brakes and he made it sound like it was my fault and would let me know the cost. He said he had no knowledge of this being an issue with the Santa Cruz. I'm bracing for a fight, I guess...
#41 ·
I've owned 30-something automobiles. Two had problems with brake judder - a 1991 Ford Tempo and a 2017, 2019, and 2021 Honda Ridgelines. My 2021 Ridgeline developed severe brake judder (the front right tire felt like it was bouncing off the pavement during moderate brake application at highway speeds such as slowing down on an exit ramp). Turning the front rotors was a temporary fix. The judder returned. The permanent solution was to replace the factory rotors with the cheapest aftermarket rotors from AutoZone.
#31 ·
"Wear items" are covered for 1 year/12,00 miles; according to their website.
See bottom line:
#35 ·
Um duh, tunes are way more important than stupid stuff like actual safety items 🤷‍♂️🤣
#36 ·
Broke rotors are $100 each and you in your driveway with basic tools or any shop on earth can do the work for a few hundred dollars.
An infotainment unit replacement is a $3-5k dealership job.
Thats my concern.
I've got less faith in 10" flat screens than 13" hunks of steel.
If my stock rotors kept warping I'd just find another brand honestly. A decent set of pads and rotors will last longer than 30k miles.
#37 ·
Point being: the vehicle is still driveable with a busted infotainment screen. Without brakes; not so much.
