Just finished the download/update to my 23 Limited, and all looks good.
Just finished the download/update to my 23 Limited, and all looks good.The update is back available this morning. The actual file shows May 17 23file. Original file was May 4
Hope this download is better than the first try.
Downloading now - will install on the drive home after work.![]()
Did you have the previously pulled update installed that had problems and now those issues are fixed?Just finished the download/update to my 23 Limited, and all looks good.
My previous update on 05/04/23 was fine and could not find any problems as everything seemed to work. Found the new update this morning and downloaded/updated the SC.Did you have the previously pulled update installed that had problems and now those issues are fixed?
Thank you for the info. How long did the update process take? Also, did you leave the SC running the entire time or did you shut it off and check on the update process later?My previous update on 05/04/23 was fine and could not find any problems as everything seemed to work. Found the new update this morning and downloaded/updated the SC.
Left SC running and update took maybe 40 minutes to 1 hour. Didn't really keep track of the time, but seemed quicker than the last time.Thank you for the info. How long did the update process take? Also, did you leave the SC running the entire time or did you shut it off and check on the update process later?
I had originally downloaded and installed on May 4th, which had an April date, everything ran fine. Downloaded/updated today the new update and all seems to be working fine. Have a 23 Limited.Downloaded and says it’s incompatible with my vehicle. I originally updated with the one earlier this month successfully.
Started the vehicle for installation and about an hour later got message that the remaining update would be completed even after the vehicle was turned off. Something new I guess, first update last year was flawless.Downloaded and saved to FD. Went to install this morning via option when car is turned off. Got error message “ couldn’t update because of low battery charge” . Talk about PIA with all of the BS …….
Looks like a HUGE upgrade for Sirius XM users. Finally!Radio Changes: (Click on thumbnails for pictures)
- Media Presets now listed vertically on left.
- Steering wheel switch now matches the list going up and down.
- Album art becomes blurred out background for screen - changes for each song.
- No separate preset pages, you can scroll through the whole list without stopping.
- MOST important, you can now Reorder your preset list to you liking.
