1 - 4 of 4 Posts
2022 Santa Cruz Limitied (black/black)
Bought my SC Sat but nearly didn’t as the drivers window seal leaks and the noise is evident at over 40mph. I did some emergency research at the dealer on google and this has been reported for the Pallisade too. The seal system is redundant with an inside and outside seal but Hyundai made them (seemingly) out of a rigid material rather than rubber. It’s the inside seal that is leaking. I confirmed it by adding a layer of electrical tape in the corner, which clearly reduced the leak. The dealer said they would certainly try ti address it, but I noted that the original repair Hyundai came up with didn’t work and in one case seal replacement didn’t work. I need to do more research but just wanted to flag this.
Water Motor vehicle Automotive tire Vehicle Vehicle door
Discussion Starter · #2 ·
The pic is one I found online from a palisade owner who actually had waterin that area.
Seal designs are different between palisade and santa cruz.
Check out the black garnish that goes up and down the B pillar to see if it is seated
1 - 4 of 4 Posts
