I purchased the hitch from my local dealer. I also purchased the 4 pin harness. It is an excellent bundle. I installed it in my driveway in less than an hour.
You drop the spare tire and pull the two rear most rubber exhaust hangers. Then bolt the hitch to the frame using 6 bolts that fit into pre-tapped holes in the frame. The wire harness plug directly in, no issues with that.
Overall it is very easy.
