The wheel lug nuts are 21mm in size. Using a lug wrench like the one supplied with the vehicle can involve a lot of short throws and resetting the wrench. Once initially broken loose, removing the lug nuts the rest of the way could be much easier with a ratchet, even a 20 volt battery powered driver, and a 21mm deep well socket, six-sided, if possible. The lug wrench is also used to crank the spare tire up and down.
