I did it by myself. It is heavy but the passenger side can be held up by the exhaust while you get in the 1st bolt on the drivers side.Did you install the hitch yourself; if so, did it take two people?
Great mods! I haven't really thought much about it until now, but does the hitch in particular change the overall ground clearance do you think?I installed side steps and hitch. Took about 45 min for the hitch and 3 hours for the side steps. It takes about 45min per side just to remove the seam sealer. View attachment 4231 View attachment 4232
It is an OEM Hyundai hitchWhat brand hitch did you go with ?
Hyundai Santa Cruz Tow Hitch (hyundaiaccessorystore.com)Wow, didn't think they were available yet.
Looks great! Was the wiring complicated to install?I installed side steps and hitch. Took about 45 min for the hitch and 3 hours for the side steps. It takes about 45min per side just to remove the seam sealer. View attachment 4231 View attachment 4232
I didn’t but the OEM harness, I got another brand that was plug and play about $50.Looks great! Was the wiring complicated to install?
Source?I didn’t but the OEM harness, I got another brand that was plug and play about $50.
Not complicated to install.
Etrailer.comSource?
Could you let us know if the side steps help keep the doors cleaner? Man mine get dirty and the local touch free car washes don’t seem to do a good job. I don’t want to risk the 20’s against the rail system on a drive through.I installed side steps and hitch. Took about 45 min for the hitch and 3 hours for the side steps. It takes about 45min per side just to remove the seam sealer. View attachment 4231 View attachment 4232
Amazon, $39. Plug and play..Source?
I don’t think it helps the front doors at all. The splash guards should help.Could you let us know if the side steps help keep the doors cleaner? Man mine get dirty and the local touch free car washes don’t seem to do a good job. I don’t want to risk the 20’s against the rail system on a drive through.
