For the roof rack, I went to the Thule site and did the “Fit My Vehicle”. It came back with Wingbars Evo 127 + Flush Rail Evo + Kit 186112. They had a quick turnaround and it was delivered less than a week after I ordered.Nice! anyway you could share the model/part numbers? Also, do you think you could fit two of those kayak holders up there?
yeah, that was what worries me, the flush rails of SC are way shorter than Tucson's, so it looks like your front crossbar is definitely mounted above the moonroofThe rails have a good amount of curvature, so this is about as flat as I could get and still meet Thule’s spacing recommendation. From where the rail meets the black plastic to the foot of the left crossbar is 8 inches. From the foot of the left cross bar to the foot of the right crossbar is 27.5 inches per Thule (~22.25 between the two crossbar feet or 35.5 from the black plastic).
There is about 2.5 inches of clearance between the crossbar and the moonroof in its tilted position (sorry about the dark photo… sun just set). Very little noise generated when driving at highway speeds. So I have no concerns about having the crossbar over the moonroof. Now, if you had a mount with clamps that go under the crossbar, that may be more of an issue.yeah, that was what worries me, the flush rails of SC are way shorter than Tucson's, so it looks like your front crossbar is definitely mounted above the moonroof
yeah, you'll need the side flush rails to install these crossbars, talk to your dealer parts department maybe they can order those railsI see the Hyundai shop has the cross bars now. But are there side rails available? My SC only has a rubber insert in the roof so I'm assuming that I don't have the side rails. Forgive me if this is a silly question.
Probably not, at least not with the cradles attached. My garage opening is 84 inches and the height to the top of the larger cradle is ~86” (in agreement with your 7’2” assumption). It’s too bad the cradles don’t fold then not in use.very cool, are you still able to fit in the garage 7'2" I assume is the height, if you leave the hullavator attached on the crossbars?
Thanks, so what do you do? detach the hullavator from the rails? detach the cradles (if possible), park in the driveway?Probably not, at least not with the cradles attached. My garage opening is 84 inches and the height to the top of the larger cradle is ~86” (in agreement with your 7’2” assumption). It’s too bad the cradles don’t fold then not in use.
I park it in the driveway. I only have a 2 stall garage but 3 cars. The crossbars and hullavator have locks on them so I’m not too worried about theft.Thanks, so what do you do? detach the hullavator from the rails? detach the cradles (if possible), park in the driveway?
