If Yakima landing pads for in there that would make it easy to add cross bars and bike mounts... 🤸🚵They run along the bed of the truck for installing accessories using t slot bolts.
Caps should be removable to facilitate?Looks like you have to cut the plastic out, so when some aftermarket rails are available I expect step 1 to be: cut here. Just seems odd if its only on SC's with the hard cover, has anyone confirmed this?
Yeah I think those caps will come off. Hopefully I'll have answers this week 🙏Caps should be removable to facilitate?
Fortunately, I have a couple power inverters if needed.I've looked at several videos pause, rewind, zoom and it sure looks like it's probably a T-slot for accessory mounts.
As regards to the rear port hole window, they need to keep it because that's the only way to safely run your extension cord from your bed AC outlet being they don't have one on the interior![]()
True, no 110v in the ****pit... there is a 12V outlet though... so I guess it depends on what you want to run inside.I've looked at several videos pause, rewind, zoom and it sure looks like it's probably a T-slot for accessory mounts.
100% agreement. Too small to be useful yet constantly annoying you by having this square hovering in your rear view.P.S. I personally hate that tiny little sliding window - seems like it'll be a distraction (and make a few blind spots) when looking out the rearview mirror.
can't believe the 'bot edited the kok out of kokpit! Too funnyTrue, no 110v in the ****pit... there is a 12V outlet though... so I guess it depends on what you want to run inside.
Nope... correct, not in the center console but in the lower dash in front of the dash. Looks like those two 12V are on all the trim levels.I did not see a 12v outlet in the center console bin. Huge oversight!![]()
Looking at the manual, I assumed this (picture) was a power outlet (#20) under the flap.Nope... correct, not in the center console but in the lower dash in front of the dash. Looks like those two 12V are on all the trim levels.
Interior Features
- 12-volt DC outlets (2)
