For most OEMs the original headlights are crazy expensive. You can just replace the bulbs in them with LEDs. Unlike with reflectors, the cutoff on the projectors means that you aren't going to cause glare to oncoming drivers with halfway decent ones.Could try ordering the factory part and installing it. Replace the whole assembly. I'd imagine the wiring is the same for both setups.
If anyone tries this. I want an update. I think we all doCould try ordering the factory part and installing it. Replace the whole assembly. I'd imagine the wiring is the same for both setups.
From the Owner's Manual:Same I want to replace the halogen bulbs but can't seem to find the size of the bulb on the manual or anywhere, so its for sure a 9005/HB3 ? I will order replace and post pictures to show the difference I hate how the DRL and the headlights don't match.
Could you send us a photo, when you get a chance, of the after with DRLs running?I just installed a pair of Auxito 9005 LEDs from Amazon. They work pretty well. They only draw a total of 60W for the pair and are far superior to the halogens. I wanted to be conservative with the wattage. The LEDs match perfectly the DRLs in color. There is plenty of space for more powerful ones like the 40Wx2 Auxitos. How to install? Go very slow. The owners manual misses half of the procedure. You only need a popsicle stick. The wheel fairings need to be very carefully popped out.. you need to only pop out maybe 1/3 of it. They are delicate aluminum/ plastic clips. Then use the popsicle stick to pop the push rivets. There are 6 you need to pop on each side. 2 on under the bumper and 4 in the wheel wheel. The rest is self explanatory. You will be just fine.
Which Auxitos did you get? I see they make several different models in 9005. This seems to be their flagship one: https://auxito.com/collections/9005/products/dd-y13-9005I just installed a pair of Auxito 9005 LEDs from Amazon. They work pretty well. They only draw a total of 60W for the pair and are far superior to the halogens. I wanted to be conservative with the wattage. The LEDs match perfectly the DRLs in color. There is plenty of space for more powerful ones like the 40Wx2 Auxitos. How to install? Go very slow. The owners manual misses half of the procedure. You only need a popsicle stick. The wheel fairings need to be very carefully popped out.. you need to only pop out maybe 1/3 of it. They are delicate aluminum/ plastic clips. Then use the popsicle stick to pop the push rivets. There are 6 you need to pop on each side. 2 on under the bumper and 4 in the wheel wheel. The rest is self explanatory. You will be just fine.
So you you only need 2 bulbs? A single LED does both Lo and Hi beams?Hi all, as requested. I’ve been running them for 2 weeks without any issue. I drive with them on 2 hrs a day for work through the dark forest in Montana and the range is excellent. I have a gripe though, because the LEDs have a thick housing, you are loosing a tiny bit of coverage. Trust me though, you don’t even notice it cause they are so bright. When these burn out in a couple years, I will definitely go for the 80watt ones 40W+40W because of their increased power and thin profile. BTW, note the new Firestone Destination A/T2s. They look amazing on those stock rims (P245/60r18) and have great traction on the road and wintery icy weather. Those OEM Kumhos are now my spare tires….
Usually on that style of projector, it just has a little solenoid inside that controls a flap that is raised and lowered. Lowered it makes a nice clean beam cutoff, and raised it just lets all the light out so some goes higher for the high beam.So you you only need 2 bulbs? A single LED does both Lo and Hi beams?
9005 LED Bulbs Mini Sized CanBus Ready 80W 16,000LM/Pair, AUXITO 9005 (HB3) LED Bulb Conversion Kit, 6500K Xenon White, Pack of 2Hi all, as requested. I’ve been running them for 2 weeks without any issue. I drive with them on 2 hrs a day for work through the dark forest in Montana and the range is excellent. I have a gripe though, because the LEDs have a thick housing, you are loosing a tiny bit of coverage. Trust me though, you don’t even notice it cause they are so bright. When these burn out in a couple years, I will definitely go for the 80watt ones 40W+40W because of their increased power and thin profile. BTW, note the new Firestone Destination A/T2s. They look amazing on those stock rims (P245/60r18) and have great traction on the road and wintery icy weather. Those OEM Kumhos are now my spare tires….
I'm concerned about the fakespot rating:9005 LED Bulbs Mini Sized CanBus Ready 80W 16,000LM/Pair, AUXITO 9005 (HB3) LED Bulb Conversion Kit, 6500K Xenon White, Pack of 2
https://www.amazon.com/dp/B07WCSJQYC/ref=cm_sw_r_cp_api_glt_fabc_MFNZJ7DNS8D7TW5CVBAT
Is this the 40W you were planning on installing? I’m considering ordering
Sent from my iPhone using Tapatalk Pro
I think the reviewer is talking about these: https://www.amazon.com/dp/B07JCSRS7HLied about 16000 lumen, returned
Reviewed in the United States on March 7, 2020
Verified Purchase
I was looking for brightest LED headlamp, so I bought this specifically because it claimed 8000 Lumen per headlamp (16000 both) which was more than the 6000 Lumen per headlamp Nineo I had
previously purchased.
I measured both Nineo and Auxito with a Lux meter (I have optical engineering experience). This Auxito measured less than the 6000 lumen rated Nineo which I also compared to a 1250 Lumen halogen. The Nineo rating looks about right compared with the halogen correcting for wider, more uniform beam width of Nineo.
Consequently, I returned the Auxito and gave it 1 star for lying about the key buying parameter, the lumen rating.
Thanks for the heads up.I'm concerned about the fakespot rating:
Basically they take away likely fake reviews and give a score based just on reliable reviews, and its average is only 2/5 stars, with some saying they died early and are not clockable (ability to fine tune to ensure they are perfectly up and down vertical).
I installed those into one of my vehicles about two years ago and they are very bright for the price and have not dimmed. They are clockable with a tiny screw, so if you see they are off, you loosen and adjust until perfect, then tighten.
I was completely unaware of fakespot. Thanks for the tip!I'm concerned about the fakespot rating:
