So I would like know everyone's opinion on what their suspension preference is or would likely be.
Why can't we have THAT color? OMG it's either that or a metallic orange wrap to be sure.You could go in between and just a mild lowering stance, not a slam where you lose a lot of ride quality. This would be about 1" lowering:
That looks great!! That’s probably what I will end up going with.You could go in between and just a mild lowering stance, not a slam where you lose a lot of ride quality. This would be about 1" lowering:
@Solkuter, Perhaps you'd like @JMII's Red Rock? When I'm in charge, Hyundai will be cranking these beauties out!Why can't we have THAT color? OMG it's either that or a metallic orange wrap to be sure.
That doesn't look bad at all. I'm good with stock though. Should give me plenty of clearance over snow in the winter - and I know some of what it's good for off-road without bumping or scraping too.
Great review! That almost convinced me not to lower the SC.Just an inch of lift seems about right to me, on par with the Subaru Wilderness. After spending a weekend in PA Elk Country doing some mild off-roading in a viewing area in Karthaus, PA I 'gently' found the ground clearance limitations, mostly just the tow hitch touching down or the front air dam gently nerfing. The factory Kumho tires were surprisingly competent in muddy/slick conditions and did great on the rocks and dirt. ( wanted to hate them as an excuse to swap 'em out, but they were up to the task. I have studded snow tires for winter and will probably just wear out the stock tires during the other seasons) I switched to 'snow' mode once in a twist-ditch scenario just to get the brake-assisted traction to kick in easier when I had a couple of wheels off. Over all it did great, but I would worry less about scrapping hard parts with a touch more ground clearance, and maybe a skid plate.
