1 - 14 of 14 Posts
SEL Premium Hampton Grey
I am getting a lot of rock chips in the paint just to the outside of both of my headlights. Does anyone know of anything that I can install to prevent the chipping?
'23 Limited AWD Blue Stone
PPF = paint protection film. The newer stuff doesn't yellow or crack over time, it holds up really well and when installed properly is totally invisible. The film might get small cuts in it but the paint under will be protected. I swear by the stuff as I have it on two track driven cars and seen first hand how well it protects.
TIP: you cover a painted surface (like the hood) don't do just some of it, do the whole panel to prevent seeing the edges and having a tiny color shift when removed.
2023 SC SEL w/AP sage gray
'22 SC Limited Hampton Gray
2022 Phantom Black with gleeming detailed lines
Thanks SmoovC, I really can not get something on the grille quick enough! I went out after the new grille install and took additional pictures of the top and bottom pieces, and I was shocked to find this! This is from the new bottom piece, (with only 28 miles of clean highway and 11 clean city street ) miles on it. And no water, dust, road debris, grit, sand nor chemical's at all, involved. ) I rinsed the spot off and wiped it with a soft microfiber towel and was nauseated to see it and the fine scratches a light wipe of the towel made on its surface. This is exactly how this starts and spreads across the whole grill. I know every Santa Cruz owner is experiencing this in one form or another and to a varying degree. It is missed or dismissed as water or dirt spots. I too, thought the same. Yet after someone else posted about their grille peeling and looking at another's pictures of huge jagged sections, I just dismissed it as mine is not doing that. Yet it was. Just differently. I have posted pictures of the new bottom piece, old bottom piece and the cloth I used to wipe it with. My findings: It is a poor thin grade of chrome. A poor bonding process used to adhere it to its substrate. No water, bugs, grit, road debris or road salt, nor chemicals are needed, to separate the chrome from its substrate. Only air velocity and air particles. My rear chrome piece's are not peeling. No peeling of rear chrome pieces reported.
* Update * The later posting has been revised.
Going forward : If this should be, and revealed to be; A decorative plated chrome or spray on chrome painted processed part(s), I have and will continue to care and maintain said parts under proper paint care.
Thanks SmoovC, I really can not get something on the grille quick enough! I went out after the new grille install and took additional pictures of the top and bottom pieces, and I was shocked to find this! This is from the new bottom piece, (with only 28 miles of clean highway and 11 city street miles on it. And no water nor chemical's at all, involved. ) I rinsed the spot off and wiped it with a soft micro fiber towel and was nauseated to see it. And what just a soft wipe of the towel did to the surface. This is exactly how this starts and spreads across the whole grill. I know every Santa Cruz owner is experiencing this in one form or another and to a varying degree. It is missed or dismissed as water or dirt spots. I too, thought the same. Yet after someone else posted about their grille peeling and looking at another's pictures of huge jagged sections, I just dismissed it as mine is not doing that. Yet it was. Just differently. I have posted pictures of the new bottom piece, old bottom piece and the cloth I used to wipe it with. My findings: It is a poor thin grade of chrome. A poor bonding process used to adhere it to its substrate. No water nor chemicals are used to separate from its substrate. Only air velocity and debris in the air. My rear chrome piece's are not peeling. No peeling of rear chrome pieces reported.
Yes! You need to get that covered ASAP! Even with the cheapest film you can find. Makes me wonder though what will happen if you ever need to remove the film. All the chrome may come with it. Thankfully my SEL doesn’t have the chrome, but it is all hyper-dipped/ceramic coated now just in case.
1 - 14 of 14 Posts
