Remove tail light assembly
6132 Views 32 Replies 9 Participants Last post by  HSC4ME
I need to splice into the reverse light wire to ad an aftermarket light strip. Anyone know how to safely remove the tail light assembly?
1 - 20 of 33 Posts
Already here with all the pics... just do a SEARCH COMMUNITY and it will pop right up.
the reverse lights are down tucked behind the bumper, I'm not sure why you wanted to remove the rear lamp assembly (side marker, parking, running, brake, turn signal)
Reactions: 1
I just assumed without checking. That will help, I will find them tomorrow. Thanks.
Two screws. One above, one under tailgate latch point. Pull straight backwards.
BUT... I don't think reverse light wiring is present at the tail light.
You are correct. I just assumed (without paying enough attention) since that's where they are on 99% of vehicles. Tucked up in the bumper, access was actually pretty easy. Thanks
Could you describe what we need to do for the access to the reverse lights? Hardware? How to get to it? Changing the bulb? Wiring? TY
All posted here ... try a search above.
Thank you for that. I have searched, and found conflicting information about what needs to be removed\disassembled, and how to go abouts gaining access.
I thought that asking someone who actually had hands-on might be helpful for me, and others.
What light strip did you purchase?
I installed an aftermarket light strip just below the tailgate. It plugs directly into the four pin trailer hitch plug and all the lighting works except for the reverse lights which aren't part of the trailer hitch wiring. To get the reverse lights to work you have to hard wire it into the reverse light wiring which is fairly accessible in the bumper.
Tire Wheel Bicycle Vehicle Automotive tail & brake light
See less See more
Reactions: 5
I installed an aftermarket light strip just below the tailgate. It plugs directly into the four pin trailer hitch plug and all the lighting works except for the reverse lights which aren't part of the trailer hitch wiring. To get the reverse lights to work you have to hard wire it into the reverse light wiring which is fairly accessible in the bumper. View attachment 3464
Why am I only now seen pictures of this beast! Post more me likeeeey!!
Automotive parking light Land vehicle Wheel Vehicle Tire
See less See more
Reactions: 5
I installed an aftermarket light strip just below the tailgate....
Hey, @Fyngerprynt, I'm thinking of getting one of those strips mainly for its additional light while reversing. I'm hoping for something very bright in a small package. Is yours pretty bright?
Also, does your light strip have sequential turn signals?
Yes it is bright but I'm not sure how much additional lighting it provides during reverse because of where I mounted it, that space beneath the tailgate and the bumper on the vertical sill edge of the truck bed liner. It fits perfectly between the screws at either end. It would be brighter if you put it on the bottom of the tailgate, but I did not want to cover my stripe or stick it to the paint. Yes, the one I purchased has sequential turn signals, I will add the Amazon link. Make sure to get the 48 inch version.
Reactions: 2
Now my SC knows what it wants to be when it grows up. Your Rig! Great Job!
Thanks, a little time, a little patience and a little imagination.
Reactions: 1
What was the length of your light? 48' or 60'?
48"
Reactions: 1
1 - 20 of 33 Posts
