I researched the OEM kit. That kit was very expensive ($200), required removing the console, had blue lights for footwells (blue color was not for me), and you had to get expensive hole saws of a certain sizes, then drill on the console and when the OEM kit was completed, then it was NOT EVEN tied to the dome or reading lights! If you wanted to use the lights, you have to manually switch them on! No way.
I did my own for under $30. And…my added LED lights come on and turn off automatically with the dome light (when you open the door or turn on the interior lights) and are the same LED color temp as the dome and reading lamps in the limited model, approx 6000k and are not blue colored. Only a few small holes of drilling required to mount a couple of homemade brackets.
What I did:
I just tied into the wiring for the dome light (2 wires) and ran a 2 conductor cable from the roof down through the windshield pillar to my footwells.
I bought the lamp sockets on eBay
Lot of 5 CEC 4087-0 Wedge Base Sockets Fits W2.1x9.2d Base Bulbs | eBay and made some brackets to mount the sockets on, out of 1/16” thick aluminum bar (1/2” wide) from the Home Depot. I mounted them out of sight (above the footwells) as in the photos, with 2 screws to a removable piece of console trim…and then stuck the LED bulb in the sockets. Completed.
Easy, but it took a while to run the wires and make the brackets. I’m very happy with the results. Why Hyundai does not include footwell lights in the limited trim package is beyond me….
The LED lamps are 194 style:
194 SMD2 LED Bulbs although any 194 bulb will work….but these seem to be the right brightness so they don’t look out of place. These particular LEDs are also available in multiple colors also….if 6k (cool white) is not what you want.
I only took a photo of the bracket on the passenger side. Driver side bracket is similar. You could easily mount these in other locations also. These are up under the dash and you cannot see the bulbs getting in or out of the car.
The existing dome light circuit in the Santa Cruz is robust and made for halogen lighting also (higher current) so it can easily handle a few extra LEDs tied to it. The service manual shows either LEDs or halogen bulbs…so I’m confident in this. Basically, all you are doing is adding LEDs to the existing circuit in parallel to the existing LEDs.
If anyone attempts this, please remember you are working on circuits that should be powered off and you may also void your warranty if you do something wrong. So do this at your own risk. It’s easy if you are careful and have basic wiring and electrical knowledge.
