FINALLY! I have the Kia 7-Pin Harness and the REDARC Tow Pro Elite Brake Controller Installed! I don't have anything to tow yet but I have a 7-pin tester and before the brake controller everything worked except the brake signal; now everything works including the brake signal. Took way too much time and I learned alot along the way:
1. Don't pay for hyundaitechinfo.com access if your looking for wiring diagrams/details on the towing connector/brake controller stuff. They are incorrect and only show the info for the non-turbo version (Hyundai did refund my subscription cost though).
2. The Kia 7-Pin Kit is plug-and-play to the 12-pin towing harness under the rear of the truck on the driver's side
3. The Turbo equipped SC have 2 extra trailer-related fuses and a 4-pin connector under the dash (up behind the fuse panel) for hardwiring a trailer brake controller
4. Be warned, if you go with a brake controller that has a box you have to store under the dash somewhere (IE the REDARC ones) there is not any great places to really mount/secure it. Something like a prodigy brake controller mounted on the outside of fuse box cover would be alot easier to install
4. Really really really don't mess with the panel/garnish right below the panel with the start/stop button. It looks like its just small piece right there but it actually runs all the way under the center screen/media system and around the glovebox and if you had to replace it you would have to take out the center console and just about all of the dash panels (and the glove box).
Now for some pictures!
- The Kia 7-Pin kit came with an adapter for the 4-pin under the dash to unterminated wires. The redarc brake controller came with an adapter from the controller to unterminated wires. The color coding between them matched up so I just used some butt connectors and covered them in electrical tape.
- Connected the cabling to the 4-pin behind the fuse panel and then had to find a place for the controller module to sit. Big thing is it has to be fixed and cannot move around. Ended up gorilla taping it to the AC duct in under the center console and added some velcro straps (added after pictures) to make sure it doesn't move:
- Mounted the knob for the controller on the right of the steering wheel. The panel this is in is the one you really don't want to take out or replace. Could have saved hours if I had put the knob somewhere else:
