All vehicles can fail. I've had lemons. I get the frustration. I'm also not one of the die hard Hyundai fans....people on here would have you believe im a hater. I'm not.Well they acknowledged the slipping\surging as they felt it on the test drives.
They are looking into why it's doing that since they have the truck for the coolant issue.
Update on the coolant issue.....hyundai engineers said it's a control unit that is most likely bad....and it's on back order.
FFS I should have just kept my Mazda CX-30
I'm not a die hard Hyundai fan as I tend to favor a specific vehicle rather than a brand.All vehicles can fail. I've had lemons. I get the frustration. I'm also not one of the die hard Hyundai fans....people on here would have you believe im a hater. I'm not.
The new 2.5 uses electronic valves to keep all water inside to reach operating temp sooner. Plus one that sends the water to the oil heater. Part of the "smart"stream system.. Likely the control unit for that system. Normally it would probably be a quick fix but in today's world parts just aren't there. For any company. Could also be the transmission issue. The transmission relies on engine temp and temp data for shift points and shifting.
Be glad you didn't get the "could not duplicate" speech.
yup! that is what mine does tooI’m having a similar issue w/ my SEL. Managed to capture mine on video. Especially does it uphill but acceleration doesn’t seem to make a difference. It’s annoying.
Here’s the video. I texted my service advisor but no answer since Tuesday…
Is it in the shop for the same transmission issue? I'm going on a road trip next Friday and I don't want to be stranded.I have now made 2 payments on a vehicle I still can't drive. Reached out to Hyundai and it's been 3 days and no response.
Did they get to the bottom of the transmission slipping? Or did they just pass that off as normal behavior?Update:
Still in the shop and part is back ordered....date of shipment is TDB so they have no clue.
I did bitch to Hyundai corp and they are refunding my my last 2 payments on it.
Which is nice but i'm still sans truck and driving a rental camry.
nothing yet....they did say it was safe to drive and I picked it back up after not having it for 33 days. Well it went back today because the check engine light came on with a code of p2181.Did they get to the bottom of the transmission slipping? Or did they just pass that off as normal behavior?
