The user manual only said visor light bulb is non LED and festoon, but it doesn't say the size so I went ahead and measured it
replacement should be 29mm festoon bulb
remove the 2x10mm bolts holding the taillight module
the inside is pretty much contoured to the shape of the module, not leaving much room to work with
the pins need to go in those white plastic holes when installed back
there is this opening on the side, but wires pass through there and I don't wish to have hot resistors mounted there either.
