1 - 20 of 27 Posts
22 Ice White SEL Activity AWD
Hi All, I'm talking about cleaning the INSIDE of the windshield, it seems mine gets a film on it every week, maybe it's all the new plastics, but it's a pain to clean with Windex and paper towels, Any tips? Or easier way? What do you use?
Thanks !
Discussion Starter · #5 · (Edited)
Inside, I use Sprayway Glass cleaner and a microfiber towel that hasn’t been washer with soap or fabric softener.
Do you spray on the towel then wipe or directly on the windshield? I'll probably go this route because I hate the smell of vinegar and I didn't know they still made local newspapers? Lol.
It’s an aerosol spray but contains no alcohol or damaging chemicals. Comes out foamy and I spray it directly on the windshield. Use one side of the towel on driver side and other side on passenger side. Works good too!
'22 SC Limited Hampton Gray
  • Helpful
Reactions: RichVee
Ammonia at a minimal ratio to wash in isn’t like using window cleaner with ammonia as an ingredient to spray onto windows. You wash with ammonia in the washer and it rinses the ammonia out. You then dry the towels in your dryer and you’re good to go! Simple not complicated!
I think the confusion may be because ammonia is widely known as a glass cleaner but not as a laundry detergent.
On the point of streaks: Pro tip: wipe one way on the inside (say side to side), and the other way on the outside (up & down). That way if you do have streaks, you can easily identify which side they are on.
Reactions: ToadVine and RetFF
I think your right too. I would no way wash any windows with ammonia period. Works well for my dry off towels with out and ill side effects. Of coarse I’m old school and have been doing it for well over 35 years!
SEL 2.5 Non-Turbo AWD with Activity package
Premium paper towels have oil in them. They will tend to streak no matter what you do. If using them, buy the cheapest on the shelf. A tip from our house cleaners
Thanks !
Invisible glass and micro fiber works well. It helps keep it from getting dirty again quite as fast. The biggest thing is not to clean it when the glass is hot, it tends to smear more.
1 - 20 of 27 Posts
