Anyone know how many watts it is rated for?
All kinds of inverters are available in the aftermarket, however based on the pictures I'd say the wiring in the SC is not beefy enough to handle such an upgrade. Can it be done? Sure... but only if you are very familiar with such things and upgraded all the wiring as necessary.Any opportunity to replace that component with beefier unit?
The 115 volt outlet on the Santa Cruz has an output of about 1.5 Amps., if I remember correctly. That is not enough to brew a cup of coffee, let alone run a crockpot. It will light three 60 Watt light bulbs. That is all. If you are asking, “Why, then, is it offered?” you are not the only one asking that question.How long do you think I could run a crockpot on warm during a tailgate without draining the battery too far?
What is the amperage draw of that fridge (and wattage, if applicable)?I used it to run my 12v fridge using a110v adapter. It worked great for me. I'm going to install a 12v power point next to the 110v so I won't need an adapter next time.
I ran the fridge for roughly 7 hours but there was driving involved, so it wasn't off the battery most of the time.
From what little I have read, inverters are made to protect themselves and stop functioning until the overload is removed. I have not overloaded one, though.So here's a question: Say you accidentally overload the outlet by plugging in something it can't handle. What happens? Does it blow a fuse you have to track down? Does it reset itself after a minute? What does it do?
There are alternatives to heating food by drawing electrical power from the vehicle battery. If you are tailgating, the vehicle is likely parked. How about supporting the stoneware liner from the crockpot over a can or two of sterno? Once it was popular among some to wrap food in foil or a suitable container and use engine heat while driving for cooking or warming food. Cookbooks for such things are even available. One is called Maniford Destiny.How long do you think I could run a crockpot on warm during a tailgate without draining the battery too far?
The 150w is good for charging cordless power tool batteries, or even powering a 60" LED TV, but not for cooking or a coffee maker or an electric blanket or a hair dryer!Anything the creates heat from electricity draws a LOT of power.
So, instead of a fuse, it has a circuit breaker. We just need for someone with a shop manual find out where it's located... maybe it's right on the inverter.... I read somewhere that if you overload the circuit it shuts down and has to be reset by a shop!
