It's fairly common, and nothing to worry about. The moisture is under the clear outer lens, and not inside the lamp assemblies, so it won't cause a short.
Personal experiece: The easiest solution is to park outside in the open sun, with the rear facing south. The sun will evaporate the moisture...
